Will these modules support this?
First post!
I'm building a really slim portable speaker that needs 20W
I can't find a 20W module to fit but i have found a 10W module.
DAMP - wzmacniacz klasy D o mocy 10W - zestaw do samodzielnego monta?u - Sklep AVT.pl
Can i strap 2 of these together? into a Mono 20W?
I've done a bit of bridging with class AB amps in the past but i'm reading that class D is obviously different and can be a little hit and miss. I heard there is the potential to put them in parallel but i have to match the digital clocks?
looking at the diagrams (i don't understand Polish) i see there is a clock sync. So maybe this is possible.
So do i tie the audio inputs speaker outputs and connect the syncout of one to the sync on the other?
Cheers
