I understand removing the ferrofluid from my tweeters will improve sound quality. Will the response be tilted up when doing this?( more high frequency). Or just more resolution all over.
Damping will be reduced, how will this sound? Any way to compensate for this mechanicly? I have already used some "puzzlecoat"
They are fairly sensitive (97 db with horn) 1" non compression dome horn drivers. I dont know if this is relevant for the results. I dont have any spare ferrofluid so trying it is non reversable until i can get a hold of some. I also dont know what the viscosity is.
Coolin
Coolin
You what?!
Change the response? Definitely. Improve it? I doubt that very much.
Since ferrofluid is part of the magnet system of the speaker, removing some of it will weaken the effective strength of the magnet. This would probably cause a peak in the midrange, a drop in efficiency at high frequencies, and a dramatic increase of possible resonances. The whole point of ferrofluid is for damping of resonances and to be able to use a smaller magnet than otherwise possible. If the manufacturer could save money and make the tweeter sound better by not adding ferrofluid, then they would've already thought of that.
CM
CM
That's what some actually did already !!!!
Some Scandinavian tweeters are deliberately marketed as having no ferrofluid (e.g. Seas No-Ferro) and they are said to sound BETTER than their ferrofluid counterparts.
But changeing a driver's properties by removing the ferrofluid might give somewhat unpredictable results (it is designed with the ferrofluid taken into account after all). The best would be to find out if someone has already done it on the very same model and what the outcome was.
Charles
Guys, please only respond if you have experiance..
I know that the theory would seem it would be a bad idea but there are experienced people that have tried it and said it was an improvement.
With regards to the magnetic strength issue, Jon Risch has said it has very little effect.
I can imagine you loose detail because of the friction in the fluid.
There are many post over at AA regarding this issue but only a few who have tried and recomend it.
Im looking for more who have done this here.
Also i have read somewhere that some Scan speak top models dont use it iether.........
Later, Coolin
Later, Coolin
I know the people at Kharma does the removal of the ferrofluid themselves, manually, on Focal tioxid tweeters. I think it would be very hard to predict how the response is affected, but one approach could be to buy an extra tweeter to experiment with.
I also think it would be very much harder to do on a soft dome tweeter than on a ceramic or metal dome tweeter.
Remove the membrane from the test-tweeter , and use some very accurate pipettes (from medical use or something) to remove some ferrofluid. Reassemble and measure. Write carefully down your results, both measurements and ammount of removed ferrofluid, and repeat the process. Remove some more fluids.. measure.. write down.. on and on..
You should maybe keep a small ammount of the ferrofluid left in the tweeter , I'm really not the one to tell you how much.
Experiment if you can afford it. When and if you can keep a smooth response with a minimal ammount of ferrofluid left or nothing at all, go for a modification of both tweeters you will use in your speakers, and remove exactly the same ammount of ferrofluid from both...
Note that even if you make it work with an improved result, the ferrofluid do have a purpose in a tweeter designed to be ferrofluidfilled. There will be no warranty if you burn your tweeters, so if you're to experiment, make sure you can afford some blown tweeters...
An approach could also be to buy some tweeters with no ferro-fluid (like the top models from Scan-Speak in denmark)
Ferrofluid provides mechanical dampening and dramatically reduces Qms [and thus Qts] of the driver and flattens its impedance curve in the Fs zone
If the ferrofluid is removed, then most T/S parameters of the tweeter would change. Qms will be higher and the driver may tend to peak near Fs before rollof ['honky' sound], even Fs may change. The crossover would also need to be redesigned since impedance curve will have different shape and a big resonance peak
A tweeter designed to rely hardly on ferrofluid dampening may be unusable after ferrofluid is removed
CeramicMan said:When and where was it established that removing ferrofluid would be a good idea in the first place? Just because some highly regarded tweeters are designed without any ferrofluid, surely it doesn't mean that other tweeters should have their's removed?
CM
As said, regarding the focal tioxid tweeters, Kharma personel does this to great success. The Equisite series and the Ceramique 3.2 RFM, perhaps the very best 2-way system ever built by man, uses these manually modified tweeters... but wether it's a good idea or not to attempt this as a DIYer is an entirely different matter. I am sure the people at Kharma have high expertise and the funds and equipment to do this in a proper manner, but my point being that there can, in some cases, be beneficial to remove the fluids if one knows what to do and how to do it (wich, neither of us really do i guess..) However, I would still say there's a 99% chance at least to get a better result by buying a tweeter that meet ones goals, than by modifying one that doesn't...
Troels removed the fluid on a Monacor tweet.. with some interesting results.
http://www.troelsgravesen.dk/C17_II.htm
He documents the results near the beginning of the article.
Photos of hte process at the end.
Tosh said:I'm resurrecting this thread to ask if there are any more current comments or experiences. In particular, I'm wondering what to expect from my Vifa D27TG35 tweeters if I were to remove the ferrofluid from them.
FF does the following:
- increases thermal conduction
- provides additional damping
- and to a lesser degree it can aid lateral positioning in the gap
It's comes in many different viscosities, with the selected one chosen for the right balance of the above. Bear in mind that removing it when the designer had some obvious intention for it is certainly going to detract from it's performance in some way.
It seems to me that the pole piece vent in this case is for increased surface area to aid cooling. The most likely reaason for blocking the top with felt is to control the effective enclosure volume using felt to prevent back reflections.
The pole piece surface area and FF in this particular tweeter might have been seen as critical for effective cooling by the designer, and thus removing it with the view that you will be improving the FR/distortion without consequences is unlikley.
Troel is quite obviously a very accomplished speaker builder but I wanted to point out that there's not going to be any free lunch here before you all start removing the FF from your drivers...
Troel mentions "The vented pole piece is covered with some heavy felt material and the hole through the polepiece is not damped at all. A bit strange. Seems like a rather simplistic approach. Why have a vented pole piece and a damped rear chamber - and then block the vent? One reason may be that the felt pad works as an acoustic vent to the rear chamber."Bob Barkto said:Troels removed the fluid on a Monacor tweet.. with some interesting results.
Troels Gravesen also experimented with removing ferrofulid and additional DAMAR coating on the D2010/8513 in his Proac Response 2.5 clone project with detail steps on page 31 :
http://www.troelsgravesen.dk/diy_loudspeaker/2.5_Clone.pdf
Apparently this reworked D2010 solved the subjective sibilance issue on the clone 2.5
Max
Max
- Will removing ferrofluid change response?
