Will any of the D-amps run on 500ma?
Is there a simple equation to figure out the voltage at 2A if I am using a buck converter with 18v 500mA input?
Also, are there other low power amp boards less prone to noise? I read a few threads about noise with PAM versions.
P = I X E
Power = current times voltage.
So 18v @ 500 ma = 9 watts.
so 9 = 2 times ? drum roll please 4.5 V Close to USB spec.
Buck converters are ~ 85% efficient so use 9 X.85 for watts out. 7.7 watts.
A class D audio amp is 80-90% efficient so you can get 5 watts of audio out which should be enough.
500 mA of average current is enough for a very high volume with audio signal and a real speaker, if you somehow provide also the high peak currents. How? With a big capacitor, and maybe with a current limiter between PSU and cap if the PSU cannot handle overload properly. No need to limit voltage this way.
