hi folks. i'm just starting out in projection and i have ordered a psone screen manufactured by wild things to use as the lcd panel. just wondering if anyone has seen or used one of these specific panels before and how good they are or how easy they are to dismantle. ive ordered the original oval version of 4" size if that helps. thanx in advance for any response.
the original sony psone screen is crap so I'm assuming this won't be any good. The res is too low and contrast won't let out too much light. If your budget is low, than maybe it may be good enough for you.
thanx for your input gizmotech. ur the only one decent enough to put a response after u have viewed.as i am a noob, im trying to get everything right before i go up to a larger vga panel and a better set up. i know the lcd will be pretty low res but ive seen some decent results with the original sony screen at about 60 inches. guess i'll just have to suck it and see. if anyone has ever disassembled this panel,i'd be grateful for any tips. thanx again.
