Hi
I have done some simulation with BetsyK in a design approach like my TABAQ. The design is very simple, and the simulation looks very promising.
I hope this can be used as inspiration
Hi from
Bjorn
Bjohanessen,
Wow, the BetsyK does look very good in the Tabaq! You would be hard pressed to find something else with 95db and performance like this fir $100/pair. It is inspiring but this would be a pretty big Tabaq.
Dumbledog,
The dimension is the cross section based on driver Sd. The sim has cross section set at 4.8 x Sd. So choose your baffle width to physically fit driver and calculate depth to get area to equal 4.8 x Sd. The specs list Sd ad 29, I assume this is in square inches. So for example, I think assuming a 10 in wide baffle, the depth will be about 11 in. However, you want to avoid a cross section that is close to square, maybe make baffle wider.
Hi Dumbledog, glad to hear.
Once you have the final external size of the cabinet I can calculate the baffle step filter.
As you probably know you can set width and depth of the cabinet as you like as long as the internal area is not changed.
Looking forward to follow your project.
Hi from
Bjorn
Hi from
Bjorn
- Full Range
- Wild Burrow Betsy Ported Speaker
