i am looking to build a speaker that can have a good bass and also goes way to the top.
my criteria will be:
1. simple designs, simple crossover.
2. not so many drivers, maybe 3 or 4.
3. under $1000 budget.
after looking for some time, i came up with these options:
1. mid using jordan jx92s in closed box.
2. scan 9500 tweeter, (because the ribbons are too expensive)😉
3. for the woofer will be a single jordan jx150 or a pair of jx150 or maybe scan 10 inch woofers in a sealed box! because i wanted the bass to be tight and focused. i was wondering if i can cross the jx150 or the 21w8565 with a 1st order xover at 150-200 hz (because the jx92s f3 at about 80 hz or so)
so what do you think, especially dave with his advance experience in building loudspeakers and with jordans drivers
thanks for the help!
regards, henry
regards, henry
