I'm working on a project using the TI TAS3103. From SDIN input I2S audio signal,but SDOUT no output. I use a MCU control TAS3103 by I2C bus. I can read and write the register of TAS3103.
I issue a command(0x00432433@0xF9).
Has anyone had this problem? Please help me,thanks a lot!
My test code
Dbuf.SubAddr = I2S_FORMAT_SUB_ADDR;
Dbuf.Data.B_Data[0] = 0x00;//0x04;
Dbuf.Data.B_Data[1] = 0x43;//0x40;
Dbuf.Data.B_Data[2] = 0x24;
Dbuf.Data.B_Data[3] = 0x33;
TAS3103_SendData(&Dbuf,4);
Dbuf.SubAddr = G_TO_Y_SUBADDR;
Dbuf.Data.B_Data[1] = 0x80;
Dbuf.Data.B_Data[2] = 0x00;
Dbuf.Data.B_Data[3] = 0x00;
Dbuf.SubAddr = H_TO_Z_SUBADDR;
I have slove this problem.
I have solve this problem. It can not work is due to I2S bit clock is not right.
I set codec as 24bit 48KHz. It can not work when I set TAS3103`s LRCLK as 48KHz,BCK as 1.536MHz. It can work when I set TAS3103`s LRCLK as 48KHz,BCK as 3.072MHz.
Tas3103
Hello everyone!
I'm new to dsp audio processing...😕
we're assigned to do a dsp audio frequency equalization +agc+ noise filtering project and I'm interested in this TAS3103 chip. Any one here that can help me to give a clear idea about this chips' capabilities?
Any source codes or advices are greatly appreciated.🙂
Hello everyone!
Please helpe me i need control that ic TAS3103 by Micorcontroller
and the software for that Micorcontroller { that software control all function and
VU Meter and Spectral Analysis ,,,, all all function } thank you .....
- Digital Source
- Why TAS3103 no audio signal output?
