Why such a large input series resistor?
In the circuit posted below, can someone please explain why the designer used a 10K ohm resistor in series with the input?
I see that the 10K resistor and 100pF cap form a low pass filter.
I typically see resistors from 100-1K ohms used in this position.
Would the circuit benefit in any way from a smaller input series resistor and larger shunt cap? Say like a 2K resistor and 1000pF cap?
Thanks...
You can put a 100pf across R22... to avoid possible oscillations at higher freqs, check with scope if needed or not.
You can also lower value of R22 and keep same ratio with R16 and R18. Lower resistor values here will result in lower thermal noise.
Need power supply 0.1uf bypass across the V+ (pin8) and V-(pin4) pins to Gnd.
I don't own a scope, so I can't check for oscillations.
I've been using 2K for R22 instead of 4.7K.
Thanks for the tips...
