Who remembers 2 foot sphere speaker
Just out of nostalgia and wondering if this kind of design was succesful soundwise.....................
(unfortunately i only saw them and didnt hear them then)
It was a while back whwn i saw them, i was about 12 jears old and it was around 1984.
They were totally white and if i remember correctly made out of something like fiberglass. They were about 2 foot in diameter and had about maby 12 3 or 4 inch speakers on the surface pointing 360 degrees H+Vertical.
The bottom had a (mid?)bass driver pointed at a piramid (which i believe was the stand as well). to spread the sound.
Does anyone remember back that far?
CO
BBN Network Technologies makes a dodecahedron that is OEM'd by Bruel and Kjaer that is used for making noise reduction measurements, but I don’t think that’s the one your thinking of.
A while back at an AES I saw a presentation of some dodecahedrons that were built with Tannoy LGM-8 drivers. They weren’t a Tannoy product, just used the drivers. I think it was intended to do the same work as the BBN/B&K product.
I had the experience of listening to some speakers similar to what I think you were describing some tome ago. They were made by a japanese company. I think I first saw them around 1990, the letening expereince was around 1995. They had a big rack of DSP processing that went between the source and amplifiers to do some sort of special spacial enhancement. I wasn’t as impressed as the "specialists" who seemed very excited about them.
The room also had a set of JBL 4412 in it that I thought sounded much better.
I just found this web site:
http://www.oddnoise.com/spheres.html
This is a photo of the Bruel and Kjaer 4296:
Well I give up, cant find them anywhere. I recall they were black spheres. They had a dozen or more transducers that I think I was told were Pioneer car speakers. I think they used speakeron connectors and stood on three black metal rods that mounted to a plate.
Dont try this at home:
Looks like an interesting project with..
a lot of 3 or 4 inch cheap HQ Tangband drivers 🙂
Maby with a sub.
The soundspheres look simular except for the lack of drivers on the sphere.
Has anyone ever heard a omnipolar system wrt imaging?
CO
Hi Coolin,
I know of a real existing spheres but have no pictures. Those are located at the acoustical department of the technical university in Delft for demonstration purposes. And indeed over 2 feet diam and completely covered with 10 cm full range speakers. How do they sound? Well for large orchestra work these sound great but a single singer sings with a mouth of over 2 feet wide 😀
Cheers 😉
Hi Co,
No, that is not the one I’ve heard. It is just a picture of a similar one I finally found on the TUD’s web site. I’ve heard the 2 feet ones you are possibly referring to. That ones were indeed painted white and there was a huge amount of small speakers mounted. I’ve heard them in a larger lecture room at the TUD some 10 years ago.
If you are still interested, maybe you can find some e-mail entries here:
http://wwwak.tn.tudelft.nl/index.html
These 2 feet speakers will be somewhere around there I think. And for sure they were DIY by some students at the TUD 😉
Cheers
