Who made it, ESL powered amp
Acoustat made a direct drive amplifier for ESLs.
The ESL-63 has transformers for drive from a low impedance, low voltage amplifier. If you want to drive an ESL-63 from a HV amplifier, you will have to go into the speaker and remove/disconnect the audio transformers and bring out the connections to the delay lines, diaphragms, and bias supply.
I_F
hi,
i know Acoustat had the active ESL with some hi pwr tubes, I never listened to it, do you know the model no. or by any chance
can you get the schematic. Generally what do you think about it, this is a big project, is worth it?
Replacing the step up trafo by direct amp, looks to be a better way to drive the units.
Best regards
Williams
