Hi everyone, I want to buy Caddock MS220 to build my Preamplifier, But i don't know where. So how can tell me,Thank you!😀
Good evening Skybird,
partsconnexion (Parts ConneXion - The authority on hi-fi DIY parts and components) does have some MS223 left. But very few choices in values. These Caddocks are expensive.
There are enough sellers which have the MP-line for sale....but the MS-line is difficult to find.
I use a lot of Caddock-resistors. As i use a lot of transmitter tubes (working on the wrong side of 1000V) these Caddock MS-line resistors are simply unbeatable.
During the years i've accumulated quite some values in the MS and MM-line. If you can specify which value you need (and in which quantities)....maybe i can help ?
Included some pictures of my latest mono-amplifier (using EL82's); again with Caddock-resistors.
Regards, Reinout
Regards, Reinout
I did some Atma-sphere mods a few years ago and used many Caddock resistors, got them right from Caddock if I remember correctly. Send them an email and see if you can purchase directly from them.
Craig
Craig
Hi again Skybird,
oil capaciters...very useful for the power supply. I do like transformercoupling in the audio-path. So it's interstage-coupling; no capacitors.
Did you find your Caddock already ? As said: make a list....maybe a forum-member had the parts you're looking for.
Regards, Reinout
Regards, Reinout
