Who can explain this FFT graph to me
If it's not to much trouble for you to come to Maastricht, I'll be happy to measure all I can for you.
Hi Gerrit,
That is very generous of you! And I might just take you up on your offer. Because I'm very curious what my latest changes are going to measure like. At the moment I'm doing the changes (tonight the 2nd unit) and then the listening starts. Hopefully the listening will be positive.
One other comment Bas, and that is to make sure with no signal present that the plate voltage on your EL84 is at least 180V - 200V, which implies at the current I was suggesting that the raw supply be in the range of 400V minimum on the other side of that 12K plate resistor. (You could also change it to 10K, but I wouldn't go lower due the loss in gain.)
Fortunately you do have headroom in the supply to get the voltages you need.
