I have a thread in digital forum
Digital volume control w/rotory encoder (no MC)
http://www.diyaudio.com/forums/showthread.php?s=&postid=483297#post483297
and I could not get any answer as to which VCA for high end use
So I am asking the question here.
any help
Gajanan Phadte
May be this is the reasonYou would be better served posing this question in the analog forum
any help
Gajanan Phadte
A vca in not very "digital"
What about the CS3310: http://www.cirrus.com/en/products/pro/detail/P2.html
Simpler with a NE572
Or as someone suggested in the first thread, connect your counter directly to a relay attenuator. There are a couple of threads about that on the forum.
Why not DS1666 from Dallas. Requires no MCU if you don't want it.
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2747
I don't regards the CS3310 as digital. It takes an analog signal and does only analog "processing" on it. You signal is always in the analog design.
If you go with relays you make identicaly the same signal path, but instead of everything in an ic, it is in several components, and you replace the fet switches with relays. But it is the same basic circuit more or less.
If you want real industry standard components, then the relays are your best bet.
Next would be making a circuit with a "two quadrant multiplier". But this is going to be more difficult. And if you really want to do it, then you can even make the multiplier discrete. Take a look at the application notes of AD for those devices: http://www.analog.com/en/subCat/0,2879,773%5F862%5F0%5F%5F0%5F,00.html
Other idea, you could steer a led with your digital signal and couple this to a resistor in the feedback of an opamp. Simple and total separation between digital and analog.
Other possibility: http://www.national.com/pf/LM/LM13700.html
That's a good one.
G. M. Phadte
- Analogue Source
- Which VCA for Digital volume control
