Can anyone tell me, which tweeter sounds better?
Raven/Esg ribbon tweeter
or
the new Scan Speak R2904/700000 tweeter
regards
Günter
or
regards
Günter
These two drivers use very different technology and are quite expensive. For sure they will sound different, but which one sounds better is a subjective question. The sound will change depending on the enclosure, crossover, room, amp, cd player, etc. Too many variables to be objective. So, I will say: I prefer the scan-speak (mainly based on their other tweeter that I listened).
And although I never heard Scan Speak my vote goes to Raven. I've been using it for 7 years now and still can't find anything wrong about it.😉
What about a Manger schallwandler? It's also a quite amazing product (and expensive)(http://www.manger-msw.com/) What about the Morel Supreme http://www.morel.co.il/index/index.htm and not to forget the tweeters which perform very well at a fraction of the cost of the above mentioned examples
So much is offerered, it doesn't end with a comparison between just two of them...
As always you have to listen for yourself and form your own opinion. Every brand has their own topproduct.
LaMa said:Manger
I hate this name because the meaning of this word in french is "to eat" 🙂 My brain can not associate it with a driver brand. Sorry to be off subject.
Here is a curve ball for ya.
If you're comparing Raven/ESg;
then consider http://www.stageaccompany.com/cdload.html
end.
If you want high impact, high spl, high sound quality,
high sensitivity;
then consider link above.
end.
If $600 is too much to pay for one tweeter;
then ignore link above.
end.
HeHEE!
end.
high sensitivity;
end.
end.
HeHEE!
I've used several Scanspeaks from the 9xxx series. Both the 9700 and the 9900 is exellent; used by dynlavy, Proac etc....
I cannot recement those drivers enough!
Thou I've never heard the Scanspeak ringradiator, I've heard from others that it's not as good as the price should indicate.
Kindly - Per.
Kindly - Per.
- Which tweeter sounds better?
