Hi!
I'm looking to build a tube preamplifier kit for an LM3886 based amplifier. Does anyone know of a good (and not too expensive) kit? The cheaper the better. 🙂
Can I connect it to the same PSU as the LM3886 based amplifier? In the same case?
Best regards
j
Best regards
j
I agree that there is apparently no need for a preamp for the LM3886 unless you want to play low level signals like that coming from a RIAA preamp etc. (about 250 mV I guess)
However I have done something similar with a TDA7294 power amp just for the sake of seeing what happens to the sound. I did not use a typical tube preamp with gain but used a Cathode follower with slightly less gain than unity ! So it's just a buffer with very high input impedance !
I used a 6992 tube and apart from the heater supply ( 6.3V ac) I used the same supply from the power amp ( +/- 36V ) to power the tube circuit.
For sure the measured performance will now be poorer than the chip power amp itself. I don't find any significant change in the sound. However for a reason I can't explain , I get more LF ( as in extended bass rather than 'boosted' bass !) from some sources ! I haven't done much comparison work but I have just taken it out of circuit and I seem to have lost 'something' ...not just extended bass ! Maybe the 'distortion...harmonics ?' If that is the case I should say ......'harmonics is good !' 😀
Note: The LF extension could not be due to the higher impedance ( 100K in my case ) of the tube stage as compared to the power amp itself ( 22K ). The LF -3dB point with the 22k itself is below 3 Hz.
Some audiophile think that a preamp is not necessary, I add a buffer tube preamp in front of my power amp, and the music opens up. Tube preamp makes it more necessary if your DAC does not have a tube output.
If you are interested I can direct you to a tube buffer from Ebay.com, it's cheap yet sounds very good.
set your chipamp gain to ~ 28times (+28dB)
If the maximum output is 50W (28Vpk, 20Vac). then the input required to give maximum output is 1Vpk or 700mVac.
Most Sources can give this and some a lot more. CDP is around 3Vpk (2Vac)
A few sources may not be able to drive the amp to maximum power, maybe only to a quarter of that level. i.e. 12.5W (10Vac) if they are only 350mVac maximum output.
So what?
Most of us listen to less than a watt of amplifier power and some a lot less than 1watt. I quite often measure just 1Vac average (125mW into 8ohms) at my speaker's terminals, when playing music from radio or TV.
So what?
A well-designed preamp should add little to the signal apart from a little noise and a little distortion - in both cases probably too small to notice - and (unless you use a cathode follower) far too much gain. A poorly designed preamp can add much more!
Jsthlm-
Seems you're getting more answers to questions you didn't ask than answers to the question you did 🙂
I second the suggestion of a buffer instead of a pre-amp if you're set on building something. If you're interested in tubes, look up cathode follower schematics. Doesn't get more simple than that. I've always thought I'd go with a John Broskie design or kit if I ever get around to trying a Gainclone-type amp.
Build it and then listen to your system with and without the buffer. Measurements notwithstanding, only you can decide which is better.
A simple cathode follower will work fine. If you add RC filters for the supply on both rails the PSRR will improve dramatically. I haven't compared the circuit with or without RC supply filtering. But I think it might be better with filtering.
If you add a capacitance multiplier on the +ve rail and CCS on the cathode, the PSRR improves even more. But is it required ? I am not sure.
Start with the simplest circuit first !
If you use a circuit with gain then you might have to use a voltage divider at the input of the power amp . You will also have a circuit with gain going wide open into the power amp and increasing the potential of becoming noisy even with the volume turned down at the input of the tube stage.
I want tubes to "open up" my music. I want the warmth that tubes are said to produce. I do not however want the high voltage stuff related to "real" tube amps. Is this an impossibility?
Which of these cathode followers should I get? GlassWare Line Stage & Headphone Amplifiers Kits and PCBs
Thanks 🙂
Thanks 🙂
"Real" tube amps don't add warmth, they just amplify.
Low voltage 'tube buffers' add warmth by adding distortion, so what you desire is quite possible.
Joined 2009
- Tubes / Valves
- Which tube preamplifier kit for LM3886 amplifier?
