Hi all,
so which member of the Spawn family would you point me to with this as T&S for an 8-incher... one of the Changs I guess but just wanted to double check.
Paba
Fs: 56hz
QMS: 5.9
QES: 0.75
Qts: 0.68
Re: 7.9
Z: 12 ohm
Xmax (p-p) 3.6mm
SPL: 94db
Pe: 30W
Sd: 239 cm²
Dd: 17.45cm
BL: 6.2 NA
Le: 0.1mh
Vas: 65L
Paba
Fs: 56hz
QMS: 5.9
QES: 0.75
Qts: 0.68
Re: 7.9
Z: 12 ohm
Xmax (p-p) 3.6mm
SPL: 94db
Pe: 30W
Sd: 239 cm²
Dd: 17.45cm
BL: 6.2 NA
Le: 0.1mh
Vas: 65L
Hi all,
Paba
Fs: 56hz
QMS: 5.9
QES: 0.75
Qts: 0.68
Re: 7.9
Z: 12 ohm
Xmax (p-p) 3.6mm
SPL: 94db
Pe: 30W
Sd: 239 cm²
Dd: 17.45cm
BL: 6.2 NA
Le: 0.1mh
Vas: 65L
which particular driver? - it may have already been vetted for a specific enclosure
I doubt it,
since very very few pairs ever made it to North America...
I have an unused pair and they are beautiful and according to Nelson Pass the high end is very extended considering there is no whizzer.
L.cao ceramic full range speakers
So what should I build?
I found a chineese TQWP plan for it somewhere but I was looking for options...
I doubt it,
sure looks interesting enough, and if Nelson has heard them in other than on OB system, perhaps he has a suggestion?
in the meantime, Scott or Dave might be able to proffer a guesstimate
