Need some help deciding which amp would be the best choice.
http://www.worldaudiodesign.co.uk/pdf/kel80crt.pdf
http://www.plitron.com/pages/Products/Audio/circuit.htm
I would appreciate some help from the tube gurus.
TIA
Franco
TIA
Franco
FrancoB said:Need some help deciding which amp would be the best choice.
I don't like the unbalanced STP (short-tailed) but suit yourself.
Yikes, a cathodyne splitter running two pair! The only time I'd ever trust such an arrangement would be with +600V supply and a chunky triode, say 12B4, for the splitter. And then the drive requirements...
A pair of 6V6, sure, but no quads, not without a buffer (a.k.a. Williamson driver circuit). Although if voltage requirements are low I'd let a CF driver pass for the buffer (also escaping the unstable tendancies of the Williamson circuit).
Tim
I'm certainly not a tube guy technically.
But I do know the second design uses "ultralinear"
taps on the output transformer, and the first is a
"monoblock" design, very difficult to compare.
Personally my much less than guru opinion
would be go for the complete WAD package.
sreten.
sreten.
