which midbass would be better?
can't decide between these two drivers
eminence alpha 10 vs eminence BP102
these are going in car doors so basically an Ib install
range is gonna be 60hz-150ish with an 18db HP and 100wrms on tap for each driver
the alpha is $42 a driver vs the bp102 $62 a driver
alpha: QTS .59 / FS 50hz / efficientcy is 92-94db over my range/ xmax - 3.2mm / sd - 355cm^2
bp102: QTS .46 / FS 40hz / efficientcy is 89-92db over my range/ xmax- 6.2mm / sd - 334cm^2
so would the bp102 work better with its lower qts or should i stick with the alpha
