Which grade is the PCM63P placed on RCD 991?
Re: 971 vs. 991
Nanook said:
I don't know anything about the Rotel player, but did find a site that indicated 971=pcm63, 991=pcm63k
look here
for the data sheets. As far as I can recall the only difference is the operating temperature range
http://focus.ti.com/lit/ds/symlink/pcm63.pdf
--> look at the table on page 3
Max THD+N at 0dB
PCM63P : -88dB
PCM63P-J : -92dB
PCM63P-K : -96dB
Unless Rotel wiped the markings, you should be able to read the exact type printed on the chip.
