I found this transformer (0120P1-2-025 Nuvotem | Toroidal transformer,120VA 2x25V o/p | 223-8049 | Welcome to RS Online) at my working place. Any DIY amp project suitable for this transformer?
The LM3875 amp is very well regarded. You can find kits at Audiosector.com DIY Chip Amplifier Kits, PCB's, Components and Information.
or you can build a simplified version off the spec sheet. LM3875 - High-Performance 56W Audio Power Amplifier
Here's a link to a thread about the LM3875 http://www.diyaudio.com/forums/chip-amps/207088-first-lm3875-impressions.html
The nice thing about the Audiosector amp is that the kit comes with a power supply board; all you'll need to add is the transformer, RCA input jacks, speaker terminals, a power switch, and a volume control (if you're so inclined). It's a great sounding small amp. Finding a center tapped transformer of appropriate voltage is a good thing; that's often one of the more costly parts of an amp build.
Mike
Mike
You have a few options:
- MyRefC
http://www.diyaudio.com/forums/chip-amps/167458-myrefc-build-guide.html
- DX Blame MKIII
http://www.diyaudio.com/forums/solid-state/193759-dx-blame-mkiii-hx-builders-thread.html
- NAP-140 clone
http://www.diyaudio.com/forums/solid-state/112453-nap-140-clone-amp-kit-ebay.html
- Tripath TA2022 amp
Medium power ampes based on TA2022, typically 2x50W
- Symasym
http://www.diyaudio.com/forums/group-buys/187592-3-symasym.html
In addition to the Gainclone mentioned above. If its your first amp, then the Gainclone seems to be the easiest build.
- MyRefC
- DX Blame MKIII
- NAP-140 clone
- Symasym
- MyRefC
- DX Blame MKIII
- NAP-140 clone
- Symasym
I will go thru it, thanks so much.
