A prototype from ten years ago.
I approve of this.
'Wattle' it take to cure your obsession with chickenheads?I approve of this.
I like it because it is simple and has a non-slip grip.
We call that knurling.
jeff
Look for manufacturers of knobs. Also, look on old radios (amateur and otherwise), and test equipment for interesting knobs.
I like Raytheon knobs (among others). Here's Openscad code for a larger one that I measured and wrote this to reproduce. With Openscad you can make an STL file of this and 3d print it:
Code:
// Big Raytheon knob.
// Ben Bradley June 14, 02018
$fn = 256;
inch_to_mm_scale = 25.4;
height = 2;
outer_skirt_radius = 2.438 / 2;
inner_skirt_radius = 1.670 / 2;
skirt_thickness = 0.060;
skirt_offset = 0.110;
neck_heigth = 0.080;
ribs_heigth = 0.635;
ribs_inner_radius = 0.8655;
top_radius = 0.8017;
top_first_heigth = 0.0165;
top_last_heigth = 0.1805;
// distance 0.81
// 0.1805 - 0.0165 = 0.164;
// 0.164 / 0.81 = 11 degrees
cube_heigth = 0.5;
under_heigth = 0.353;
under_radius = 1.4565 / 2;
rib_radius = 0.030;
number_of_ribs = 60;
rib_radius_inset = 0.01;
rib_surround_radius = ribs_inner_radius - rib_radius_inset;
module ribs (ribs_heigth, rib_radius, rib_surround_radius, number_of_ribs)
for (i_angle = [0:360/number_of_ribs:359])
rotate([0,0,i_angle])
translate([0,rib_surround_radius,0])
cylinder (ribs_heigth, r = rib_radius, center = false);
} // module ribs (ribs_heigth, rib_radius, rib_surround_radius, number_of_ribs)
module slant_top()
rotate ([11, 0, 0])
translate ([-outer_skirt_radius, -outer_skirt_radius, skirt_offset + skirt_thickness + neck_heigth + ribs_heigth + top_last_heigth])
cube ([outer_skirt_radius * 2, outer_skirt_radius * 2, cube_heigth]);
rotate ([-11, 0, 0])
} // module slant_top()
module body()
difference ()
union ()
cylinder (skirt_thickness, r = outer_skirt_radius, center = false);
translate ([0, 0, skirt_thickness])
cylinder (skirt_offset, r1 = outer_skirt_radius, r2 = inner_skirt_radius, center = false);
translate ([0, 0, skirt_offset + skirt_thickness])
cylinder (neck_heigth, r = inner_skirt_radius, center = false);
translate ([0, 0, skirt_offset + skirt_thickness + neck_heigth])
cylinder (ribs_heigth, r = ribs_inner_radius, center = false);
ribs (ribs_heigth, rib_radius, rib_surround_radius, number_of_ribs);
translate ([0, 0, skirt_offset + skirt_thickness + neck_heigth + ribs_heigth])
cylinder (top_first_heigth + top_last_heigth + 0.005, r = top_radius, center = false);
} // union ()
slant_top();
cylinder (under_heigth, r = under_radius, center = false);
} // difference ()
} // module body()
module draw_to_scale (n)
scale ([n, n, n])
body();
} // module draw_to_scale (n)
draw_to_scale (inch_to_mm_scale);
jeff
Yes, I like knurling . . . as long as it's not gnarly knurling.
Code:// Big Raytheon knob. // Ben Bradley June 14, 02018 $fn = 256; inch_to_mm_scale = 25.4; height = 2; outer_skirt_radius = 2.438 / 2; inner_skirt_radius = 1.670 / 2; skirt_thickness = 0.060; skirt_offset = 0.110; neck_heigth = 0.080; ribs_heigth = 0.635; ribs_inner_radius = 0.8655; top_radius = 0.8017; top_first_heigth = 0.0165; top_last_heigth = 0.1805; // distance 0.81 // 0.1805 - 0.0165 = 0.164; // 0.164 / 0.81 = 11 degrees cube_heigth = 0.5; under_heigth = 0.353; under_radius = 1.4565 / 2; rib_radius = 0.030; number_of_ribs = 60; rib_radius_inset = 0.01; rib_surround_radius = ribs_inner_radius - rib_radius_inset; module ribs (ribs_heigth, rib_radius, rib_surround_radius, number_of_ribs) { for (i_angle = [0:360/number_of_ribs:359]) { rotate([0,0,i_angle]) translate([0,rib_surround_radius,0]) cylinder (ribs_heigth, r = rib_radius, center = false); } } // module ribs (ribs_heigth, rib_radius, rib_surround_radius, number_of_ribs) module slant_top() { rotate ([11, 0, 0]) translate ([-outer_skirt_radius, -outer_skirt_radius, skirt_offset + skirt_thickness + neck_heigth + ribs_heigth + top_last_heigth]) cube ([outer_skirt_radius * 2, outer_skirt_radius * 2, cube_heigth]); rotate ([-11, 0, 0]) translate ([-outer_skirt_radius, -outer_skirt_radius, skirt_offset + skirt_thickness + neck_heigth + ribs_heigth + top_last_heigth]) cube ([outer_skirt_radius * 2, outer_skirt_radius * 2, cube_heigth]); } // module slant_top() module body() { difference () { union () { cylinder (skirt_thickness, r = outer_skirt_radius, center = false); translate ([0, 0, skirt_thickness]) cylinder (skirt_offset, r1 = outer_skirt_radius, r2 = inner_skirt_radius, center = false); translate ([0, 0, skirt_offset + skirt_thickness]) cylinder (neck_heigth, r = inner_skirt_radius, center = false); translate ([0, 0, skirt_offset + skirt_thickness + neck_heigth]) cylinder (ribs_heigth, r = ribs_inner_radius, center = false); translate ([0, 0, skirt_offset + skirt_thickness + neck_heigth]) ribs (ribs_heigth, rib_radius, rib_surround_radius, number_of_ribs); translate ([0, 0, skirt_offset + skirt_thickness + neck_heigth + ribs_heigth]) cylinder (top_first_heigth + top_last_heigth + 0.005, r = top_radius, center = false); } // union () slant_top(); cylinder (under_heigth, r = under_radius, center = false); } // difference () } // module body() module draw_to_scale (n) { scale ([n, n, n]) body(); } // module draw_to_scale (n) draw_to_scale (inch_to_mm_scale);
Yes me too but the surplus supply became touch and go.
When some are located they are expensive.
Thanks for the cad file.
Here's an interesting video on cloning knobs:
YouTube
To restore or repair the knob's white fill use Brownells sticks.
I've used them to correct poor application on some RCA mixer knob reproductions.
Comes in white,red,gold and black.
LACQUER-STIK ? LACQUER-STIK(R) | Brownells
I have a pun generator. It's a machine fitted with a drawcord. If I want a chicken pun I just 'pullet'!I think you’ve cornered the market on foul puns.
Since 'The' knob is in front of pecking order, hen ce asking, what alb u men think about sleek version ?
- Member Areas
- The Lounge
- Which company has the best looking volume knob on their amps?
