Which audio buffer design is the best for Gainclone?
Lee
here it is, my psu, including the tube part:
Actually, I did not use regulators for the opamp, but maybe it is better? I will try it.
I simplified the schematic of my hybrid amp:
I removed the cathode bypass capacitor. This way, there is local current feedback in the tube stage, this way reducing the gain and distortion.
It should be possible, to build a push pull amp with two EL84, what give 10-15 watt.
Just an idea... 😎
Franz
Hi Franz,
A simple LM317/337 PSU will do.
Make it like on the amp, that is, with the same component values for Cadj. (33~47uf cap) and the small film cap on the output (47~100nf).
It works very well on the LM338, and also on the LM317/337.😎
Oh, you should have good regulation if you want to bias the op-amp into class-A, don't do it with an unregulated PSU.
I see you have now the OPA637😉 , with a gain of 21.😱
I see you have now the OPA637 , with a gain of 21.
No, Carlos
I still use the 627, as I have just this type. But I wrote 637 in the scratch drawing, because it uses gain.
BTW: whats wrong with a gain of 21?
You're confusing me more and more with your so called "class-A". Class A-amps normally really don't benefit from regulated supplies!
Franz
