I got many sample ICs from TI, OPA604, OPA627, OPA637, BUF634P, NE5532 and OPA2134. Now I'm planning to do some audio buffer for my Gainclone both NIGC and IGC. I have searched in this website to find out some schematics and got a Carlos's design for the web. I have made the PCB for testing and will be got it on this Saturday. Could the members in this website advise me which design is the best for Gainclone?
I'm not sure if you mean which opamp circuit is best, or which opamp. 😕
If you use the circuit you got from Carlos, you will have a good one. If you use sockets for the opamps, you can decide which opamp you like best. 😉
planet10 said:no 6922, ECC99, or 6H30pi in that list ...
dave
Gencard, the OPA627 is the best one from your list.😉
And until today, from my op-amp list too.😀
For me, I think tube price is expensive than opamp and in currently, a few tube manufactories are still producing and very a good tube is so expensive too. By another way, Opamp is so easy to find and not too expensive. However, I have a plan to make a audio buffer by 6922 as soon as possible. 😀 .... after I have finished the audio buffer by opamp.
627's are pretty expensive (but not for carlosfm, he has a machine that spits'em out i remember 😉)
If you already have the opamps, the OPA627 is the best no doubt plus maybe with an BUF634, especially in you have an inverting gainclone with a rather low value of the input resistor.
If the price matters, OPA134, 2134 is probably the best in your list. If you can chose freely you have tons of good opamps!
I myself have chosen AD8620 but it comes only in surface mounted package.
More info here.
More info here.
matjans said:627's are pretty expensive (but not for carlosfm, he has a machine that spits'em out i remember 😉)
There's also a tree with that fruit.😀
peranders said:If the price matters, OPA134, 2134 is probably the best in your list.
Yes it is.😉
TI suggests 12 USD as 1000 price for the cheapest version.
The price in Sweden for 1-9 pcs. is around 40 USD
I think the OPA604 is the best sounding pre/buffer for the LM3875 😉
-the design is standard NI with gain=6-10dB and a shunt volume control in front of the '604
gengcard said:I think tube price is expensive than opamp
It is usually the power supply that is more expensive... but you can scrounge.
peranders said:12 USD -- 40 USD
ouch -- my 6H23pi (aka 6922) cost a dollar each...
most expensive part of my tube buffer is the CCS on the bottom of the cathode follower.
dave
carlosfm: Until today?
air said:carlosfm: Until today?
Yes, I mean it's my favourite.
😎 down, I didn't find anything better today.😀
The opa627 is in fact a very good opamp. Actually, I run this testconfiguration, converted temporarly out of one of my EL84 monoblocks:
Absolutely great sound: driving a single end tube by an practically errorless opamp!
I must do some tuning (overall feedback from the secondary side of the OT to the inverted input), enhance gain from the opamp a little bit.
Actually, this circuit shows a little bit overswing, wich must be from the output transformer.
Franz
P.S.
The input poti is a fostex "black beauty" attenuator, out of an defective PA-Fostex amp from the fleamarket. There where two of this famous things inside this amp, so I have two monoblocks running with this nice parts at the input and spent just some cents...
Franz
P.S.
Franz G said:The opa627 is in fact a very good opamp. Actually, I run this testconfiguration, converted temporarly out of one of my EL84 monoblocks:
A very interesting circuit -- what is the B+. I'd be very interested in your results as you fine tune it.
dave
I want to learn, how to make this quotes...
The Ub of the EL84 is 314V.
The testarrangment looks horrible like this:
This are some EL84 SE, showing (without feedback) the same overswing in the tube driven version. The schematics of the tube amp comes frome here (scroll down):
http://www.audiokit.it/ITAENG/KitElettr/KIOM/Giochino/Giochino.htm
I use the very good and cheap trafos from
www.roehrentechnik.de
Franz
P.S.
Imagine, what this circuit opens for new dimensions, in tweaking: just open your cd-player, replace the output opamp by an very good opamp, give hime some gain (cut one trace and put in one resistor) and add at the output an EL84 tube, or a 6V6 or...
Franz
P.S.
TI should give me a tree that gives this fruit, just for loving it so much and making publicity of it.😀
carlosfm,
I am build your GC AMP which you provide on the forum with regulated PSU & buffered inverted GC. But I am not very sure about those components spec., could you please guide me on those spec. I really need the list of components. I want to start DIYing it as soon as possible.
I just want to build the best GC for my ear.😕
Thanks.
Thanks.
Tomorrow, I will get my PCB and then, listen the sound of OPA627. Oh! it's so long time for me to listen it... 😀
After I finish this project, I will try to design NE5532 for my GC because it's so cheap in my country but I have no idea for its sound. Maybe Carlosfm well know in NE5532 sound. Right? 😀
Have anyone tried OPA228? Please tell me its sound. Thank you.
However, ADI op amp is so expensive for me.
But I'm still want AD797 for my future project too.
- Chip Amps
- Which audio buffer design is the best for Gainclone?
