Which Amps for Beyma TPL-200/H and 10-12" Bass/Low-Mid?
With more reading, I believe I have converged on an AMT, the Beyma TPL-200/H (or perhaps 150/H) to cover from 1,000 - 2,000 Hz and up. The drivers are rated at 102 dB SPL at 1W/1M, respectively, with nominal impedances of 8 ohms and DC resistances of 4.9 ohms.
What amp would best complement the driver? It will be mated, with an active xover, to a high efficiency 10"-12" bass/low-mid (TBD). The latter will cover between the Beyma and an active 18".
Nelson wrote that one of the beauties of active systems is the ability to match driver with amp, so...
Which amp for the Beyma?
Which amp for the bass/low-mid?
I have Toshiba JFETS and Sony SITs.
I need amps that have clear design briefs - I am not an amp designer by any means.
TIA.
