I know that the answers to this question are numerous so I will try to narrow it down a bit.
I have build a TA2020 a LM3886 amp and a LM4780 and the ultimate goal in the future is to build a big Class A monster.
But for now I am looking for:
Class a/ab
+/- 70 Watts at 8 Ohm
Capable to drive 4 Ohm
Compact size
Good bass
No SMD soldering…
Well documented/build guide
Good quality (for a nice price)
Amp that does not heat up to extreme temperature because of the enclosure I have and want to use
And maybe I want to build two (or four channels) so I drive my bass units separate.
What do I have: (to save some cash)
2 toroids 2*25V 225VA
Two Naim shoecase cabinets
Dact CT-2 attentuator 50K
On the following amps I did some reading
Akitika GT101
VSSA
The wire LME49830
First One mosfet amp
Naim NAP140 clone
A lot of eBay amps
Group buy threads
And some threads with the similar question
I do like a challenge but I rather avoid problems so I would appreciate your idea on what to build.
Class a/ab
Compact size
Good bass
No SMD soldering…
Akitika GT101
VSSA
The wire LME49830
Naim NAP140 clone
A lot of eBay amps
Group buy threads
P3A
This is a very popular amp that I plan to build one day soon. I think your toroidals will be suitable for Rods recommend psu design. Hope this helps. Good luck
High Quality 60 Watt Power Amplifier
@Xerxes: Since a well designed PSU has more effect on soundquality than a hand-full of watts more, I would not worry about the ~55W. Search this website for ideas on PSU's. Since you have two toroids, I'd go for a double mono configuration. Pay attention to proper suppression of all the garbage that is also supplied with your 230V mains.Hi Xerxes, you'll fall slightly short of your power target with those transformers. Expect ~55W from 25VAC secondaries.
I wholeheartedly recommend the VSSA (or one of the through-hole derivatives).
Thank you for the input.
To answer the question about a kit: I would like a pcb with at least some parts and some recommendations.
today I will do some reading about the proposed amps, they look very nice.
I will settle for ~55W
The reason why I like some sort of short guide is that I find it difficult to filter all the opinions and solutions out of the (mostly) long threads.
I was just the MX50 thread...are you a mind reader?...
The thread you replied in started with a question about the different versions, which did you choose?
And there are also posts about tweaking the board are you or have you implied these?
And I agree that it is a low-cost option
I bought the MX50 se. IT took 2 weeks to get. Nicely packed. All the parts are there and they look decent. The actual board is tiny. You can fit 2 on 1 heat sink. My only surprise was the outputs were not marked PNP orNPN. I work slow & it took me several hrs to stuff the boards. You need good eyes and a skinny soldering tip (no dogs or cats, kids, because the parts scatter easy). I use a flux touch up pen to get the solder to flow good. Then take a tooth brush and generic paint thinner to remove the flux. I have the boards mounted on the heat sink. Now I'm working on input/output jacks & wiring the power supply. I couldn't resist the price. I have VASS amp boards on the way for some real fun.
Xerxes, a new "group buy" for VSSA clone boards has popped up:
http://www.diyaudio.com/forums/group-buys/251782-vssa-through-hole-version-jason.html#post3831506
I would jump on it if I were you.
We often use Q to denote the use of a transistor, a sort of shorthand if you will. In this case the 1Q is the transistor that is the active element in the constant current source, the LED is used to provide a reference voltage and the trimmer is adjusted to set the current.
To confuse things, in electronics Q also represents a quality of reactive components like inductors and capacitors. It is about context.
- Which amplifier kit to build
