Im in the stages of getting all the stuff i need for a system to run in my truck. My question is what amp/amps would do better for me as far as whats going to be louder and sound better the colossus xx 3200 rms or 2 orion 2100 hcca's running 4 12" digital design 2512's any help would greatly be appericated i know its gonna be about the same wattage if i run 1 amp vs. 2 but not to sure about the quality and true rms power from the colossus
if the Orions are in proper working order you may get better sound quality out of them. but sound quality with regards to bass is up to the individual. raw power vs. accuracy. your enclosure size and type will probably have the bigger impact here.
You'll also want to be sure to run them at the proper load to achieve the best damping factor. If the colossus is actually 3200 watts it could still have a lame damping factor. Find out the damping factor the amps will provide when loaded with the woofers.
The best sounding sub setup I have ever heard used 12X Jensen (cheap paper drivers, not even Jensen’s best) 12" drivers, iso loaded. The box was designed and built by renowned speaker engineer Jerry McNut from Eminence.
It was powered with a variety of different amp combs for testing but they all sounded surprisingly good, not excessively loud (for 6 exposed diaphragms) but very musical. The ending cost for the drivers was something in the 225 range....
Nothing about any of the components SHOULD have sounded good. I would have told you it should sound like poop if you told me what it was before I heard it.
Both the amps mentioned are good but just as I have seen bad components sound great I have seen great components sound bad. I couldn’t tell you what would sound better. A good sub match with the power in a box suited and tuned for the vehicle will have a much bigger impact overall..
Performance will depend a lot on box design and placement/integration on cabin acoustics and on filtering/EQ. See this thread: http://www.diyaudio.com/forums/showthread.php?s=&threadid=115522
Amplifier choice is not that critical...
EVA:
And that's pretty much a blanket statement for car audio.
Tim
Tim
Those cheap and efficient subs can sound really nice properly setup. I used to run paper pyramids and wish I could buy them now they have changed. They only lasted a couple years of abuse though, but at $15 each who cared? And right, a specific amp worked better on them and made quite a difference.
your saying digital designs is cheap as in junk?? ive seen the subs out perform kicker solo barics any day of the week and also alot of other subs that people say are the bomb all i was wondering was what amp or amps i should use to get fulloutput out of them and the amp not being so damn power hungry
- General Interest
- Car Audio
- which amp to use??
