Which amp should I build?
I have Marantz SR7400 and Paradigm speakers. The receiver is rated at 105Wx7. I'm very new to the whole DIY on amp but I would like to build something that will give me about 150-200W/channel as I tend to push the receiver too much 🙁
Is it possible? If it is, which one should I check out?
Thank you!
What about the Opti-MOS?
If I were in your position, I'd try the Randy Slone Opti-MOS design. Schematic is available on his Website, and his books will give you a lot of background material and full information about the circuit, among other things. I presume you don't mind MOSFETs, considering the other suggestions too are along those lines and at high powers MOSFETs are easier anyway.
I found his books excellent, BTW.
Tarun
Re: What about the Opti-MOS?
Tarun
I second that with no reserve!
