if it were built like Karlson's 1954 12" enclosure it could have a gap vent right above the shelf. If it were built like Karlson's 8" enclosures it would have two or three horizontal slots in the upper portion of the reflector. I've no way to model these effects - maybe someone good with MJK's sections could see a trend. This coupler will be to try FE206EN and maybe W8-1772
Freddi: why not at the top of the curved deflector? Leave a gap stopping short of the top of the cabinet and maybe even a small sized angled horizontal cross piece along the top inside edge of the tapers. I have had good results with my K-Lines venting the rear line into the front coupler chamber at that location.
Hi Moray - that's pretty much where Karlson put it in his eight inch 8K coupler of the 1960's - here's a plan
http://img404.imageshack.us/img404/3346/karlsonk860s.png
Freddy
There were some different version of openings - I remember the 8 - 12" Dutch version having slots and the 15" having a big vertical slot.
I do not think that the location is that important however remembering having to put a "hard" finish in the front chamber in order retain the highest frequencies I would seriously consider not having an opining exactly behind the slot.
At this moment my thoughts for myself are towards making a small horn with an opening like Bill Woods has (which is the only horn he has kept). This will be either some scaled model of the Bill Woods model on his website or alternatively using the BK10 and putting a Karlson slot in front.
One thing I have thought about but never tried was making the opening from the second reflex chamber to the front chamber a Karlson slot too with a surface area equaly to the orignal opening.
Good luck with your experiment, I like the design.
AM
AM
