where to put wires on volume control pot
ok here, i got some pictures of exactly what i want...maybe this will make things easier.
this is the old setup. a very simple line in, line out with the volume contril pot in the center.
this is the old pot.
these are the cables.
this is the new pot.
what im trying to do it replace the old pot, on the left, with the new pot, on the right.
You can make things a lot easier for yourself if you take both the cables in the last pic and simply connect them together. Then just use the volume control on the iPod.
If you insist on using a pot, you will need to purchase a dual gang pot. What you have there looks like a single gang pot with on/off switch or something else, but not dual gang.
