F6
Would that be AudioXpress? I better hurry up and renew my subscription. 🙂
F6 is upcoming DIY
F6..........!!
Perfect timing..... my soldering iron is just cooling, from my F5 build.....
(I wonder if I can get a good second mortgage on my house.....)
What's F6, an Aleph J with power JFETS?
FW model of Aleph J with Power JFETs is called J2. I am sure F6 is different....though I don't mind building a J2, if revealed...
There is not an official public J2 schematic, but a good facsimile can be had
elsewhere on this forum.
I've been interested in taking a shot at the J2.
I have to say the optocoupler throws me. Does CTR matter? Do you need to tie the base of the output to anything or does it float?
I've had a few friends try a "J2" and blow out their SemiSouths. Any rudimentary explaination of the optocoupler would be welcome.
I'm even dumber ;
here it is - for next 16 hours it will be download-able ....... assuming that I understood Papa's reaction correctly ....
http://dl.dropbox.com/u/20665608/FW J2 unofficial schm.pdf
I'm even dumber ;
http://dl.dropbox.com/u/20665608/FW%20J2%20unofficial%20schm.pdf
at least you didn't "Rick roll " us 😉
Hmm, should I save the Semisouth JFETs I bought for an F2J and use them for an F6 instead?
No, the F2J sounds really good. You can always peel them out later.
Decent solder wick is the best tool I use in this hobby!
😡I'm even dumber ;
I'm even dumber ;
Why are you having Q1 and Q2 in backwards?
Magura 😉
I recall that the mighty ZM did cobble together a reasonably good schematic,
perhaps he will post it again for you.
Pa
you know I'm dumb
these days I'm even dumber - no comprende hints very well
only if you say - yay , ZM will post Babelfish J2 schm
you know I'm dumb
- Where to go after the F5?
