Where to get metal pushbuttons like those found on CD players?
mind you, not power switches. something like in the attached picture: small metal pushbuttons which will be attached to switches.
have them made for You. 😉
Just ask a workshop to cut and turn them for You off of a piece of steel or aluminum rod. A slightly rounded top for smart looks and either a flat bottom to glue the knob onto the lever of a tactile switch, or a axial hole drilled into the bottom to fix the knob on the axis of a pot.
See KB-AL30R at VT4C menue "Knobs". You could have something similar with smaller diameter beeing made from a massive Aluminum rod.
Or source a knob from HiFi DIY Site - VT4C/211 Power Triode
jauu
Calvin
