where to find a 10 led bargraph like this one?
I'm looking for some led bargraph like this one with the black led holder. Just the bargraph not the PCB.
Does somebody know where to buy?
I would find some commercial product that uses them. I work in pro audio, and many mixer have LED strip VU meters. Older ones tended to be larger, but I don't know what size you want. Large console mixers to little DJ mixers use them, and you could probably source one from some of those companies. I would call Peavey, but you don;t appear to be in th USA.
Hunt in general for "LED bar graph arrays" or similar
I see some at Jameco.
Digikey sells them, go there and search "LED array", then check the 1x10 on the filter parameter list for some examples.
Same at Mouser, search LED array and use the filter.
