Im currently using a Bi-radial horn for my Eminence PSD2002, and was wanting to upgrade to a constant directivity horn. The XT1086 seems to be highly recommended, but I cannot find it. Also, I will be using a DCX2496 to do a 8th order either butterworth or LR filter at 1.2khz. Will this work ok? Looking at the beamwidth graph, it seems the horn starts increasing dispersion in both the horizontal and vertical planes quite a bit below ~1500 hz.
Thanks!
Thanks!
