Where to buy Radio transmitter receiver moduls for DIY wireless speakers?
Dear friends,
My plan is to build very simple set of 5 separate active speakers (based on full range drivers, no crossover) and feed them audio signal wirelessly by radio waves from a single source - computer, phone. Preferably, via a DAC.
Now, what is the exact name of the equippment i need to do that? I mean the parts needed to convert signal from the DAC into radio waves and - on the amplifier side - to feed the amps with audio signal carried out by radio waves?
I guess its called radio transmitter / receiver or transciever? Where exactly do you recommend to buy them? What brands? Do I need anything else to connect transmitter to the phone / DAC? And on the other end, any other parts to connect receiver with standard class D amplifiers?
Can such whole project be done if I have little knowledge about electronics, just basic knowledge about audio gear?
Thank you.
Watching this thread. I too have been looking for such an animal. It's only for surround, so I don't care about hi-fi standards, just convenience. I hate the idea of losing all that signal through wiring and it looks nasty.
These are presumably too low-end for your project, but there are more from various kit pcb makers on the auction sites. I’m using one to make a shop system more user friendly soon.
DIY Bluetooth Audio Receiver Board Bluetooth 5.0 MP3 Lossless Decoder ModulMJnd | eBay
I have a pair of 2way, 5.5” powered speakers that I made using these boards, are powered by common laptop power brick.
200W Bluetooth 5.0 Amplifier Board TPA3116,FOSI AUDIO 100W+100W Audio Amp Board | eBay
Try and stick to the Bluetooth 5.0, is worth it.
The problem is 5. Things audio seem to come in 2's, 4's, 6's. For example a elegiant bti-066 is a two channel wireless transmitter receiver, uses BT 5.0. I've never heard of a 3,4,5 channel BT device.
What's the 5 speakers each going to be doing? Each mono, two stereo, one mono the other two reverse stereo? Can the receiver handling all 5 be in one place, or does each speaker have to have their own receiver - no wires to a common point allowed?
They say with the latest BT you can get two headphone pairs, paired - that's 2 channels out to two receivers. If you want 5 independent channels with a rotary switch (1 through 5) selecting which channel on each speaker, I wouldnt know where to begin.
Thanks for all replies. It seems that bluetooth will be problematic here, as it can only connect one source to one amplifier /active speaker.
My idea is to have 5 , separate stereo speakers all receiving audio signal from 1 source. Can bluetooth do it? I dont think so. Thats why radio waves perhaps?
Its like having 5 stereo radios around the room.
But - i want each speaker to have opposing left - right channels, so each fire sound 180 degrees apart from each other , in opposite directions on horizontal axis.
5 of these will fill the room evenly with both channels.
Its omnidirectional setup, just not with 2 speakers radiating 360deg but with 5 , two-channel speakers radiating both channels in many directions.
Can i transmit music from my PC by radio waves?
And then catch such signal at each of my 5 speakers?
Check partsexpress.com again. They seem to have a few solutions for single transmitter/multiple receivers, here's one of their products. Not sure this is what you need:
