where to buy cheap 15 in flat screen monitors??
15 INCH FLAT SCREEN lcd ?????
i supose you mean 15"0 LCD screen?
try WAL MART or Costco
Costco sells Sylvania for pretty low prices around $280
and Wal mart was just slightly above .......
however 1) i have had 2 sylvania monitors: the 17" one (cost $169.99)for a year and a half, the other, a 19"one ($199.99) for 30 days,.... both times i had to run back to costco and get my money back in a flash. the guy who helped me said they don't fix anything , just give the same article or your money back whatever you choose. after the second time i took the money and spent $99 on a recycled 19 inch at pc recycle in federal way and the $115 balance on dvd's )they refund you 100 pct including salestax!!!)
i have no experience with Walmart service.
one thing i know for sure i will NEVER buy a Sylvania screen anymore no flat and no lcd. rubbish!
the guy at PC recycle told me they don't even take Sylvania in, they all die within the shortest time some have they color modules fry, some have the current sensor just disappear ??......
monitor
i think i made it too confusing....
flat screen is not the same as LCD screen !!!!!
i am talking about a recycled (refurbished) flat screen monitor 19" MAG innovasion that's all
i think it was a good deal but later that week they had Sony's for $129 and i still think i should have bought a SOny.
i think that when you look around in those refurbishing stores, sometimes you can get a good deal. especially when you are looking for peripheral.... the pc'sitself do not always turn out to be a good buy!
I was thinkking abotu geting this one, ANYONE KNOW WHERE I CAN GET ONE AT A DECENT PRICE OR USED???
15 in. KDS -5C TFT LCD DISPLAY MONITOR
They deliver brilliant picture quality and are equipped with built-in speakers. Plus, it is wall mountable!
LCD Panel
Type : TFT Active Matrix LCD
Pixel Pitch : 0.297mm (H) x 0.297mm (V)
Max. Colors : 16.7 Million
Contrast Ratio : 300:1
Brightness : 220cd/m2(Typical)
Video
Video Input Analog : RGB (0.7Vp-p, 75ohms)
ync Type : H/V Separate
Input Terminal : 15-pin D-SUB
Synchronization
Frequency : 31~60kHz(Horizontal) 60~75Hz(Vertical)
Raster Specifications
Max Resolution : 1024 x 768 @ 75Hz
Electrical
Adapter : AC 100~240 VAC, 50-60Hz
On Working : < 40W
Standby, Suspend, Off : < 5W
Physical
Dimensions(Panel) : 404mm (W) x 371mm (H) x 148mm (D)(15.9" x 14.6" x 5.8")
Dimensions(Box) : 461mm (W) x 472mm (H) x 195mm (D)(18.2" x 18.6" x 7.7")
Weight(Net) : 5.2 kg (11.5 lbs)
Weight(Gross) : 6.8 kg (15.0 lbs)
Features
General : Plug & Play, Built-in Stereo Speakers, Wall Mountable, PC & Mac* Compatible
OSD Controls : Yes
Speaker : Handling Power 2W max.
Regulations : UL/cUL, TUV/GS, FCC-B, DHHS, CE, VCCI, BSMI, CCEE, C-Tick, TCO 99
Tilt Angle : -5, +45
