Google says its Metallized PET Stacked. I dont see this kind of cap often, where is it used?
I see. Hard to say, I mean they look like the stacked film type but they could be anything. If I had to guess based on this appears to be a cheap chinesium thing, they're regular poly caps epoxied into a big can to look expensive.Nono, those two big behind pot.
Any chance someone can tell me which are these two big input caps and those 2 little between them?
You can't tell without a schematic or tracing the board to produce one. Big ones could be coupling. Then again, could be something else.
A cap provides a function that can be used in many places in a circuit.
BTW This type of cap is at least 40 years old. Polyester film caps. Used wherever a, well, cap, is needed ;-)
Someone found a NOS stash.
Jan
No, I have a box of those. From Philips in the 1970's. Siemens made them also.
Good caps actually, low inductance because of the end metallisation, all cap elements in parallel.
Jan
Jan
Schematic is simple they are input audio capacitors and they are in parallel.
I have found this in local store
47nF/400V | Silken Electronic
MKS, SIE, 10%, RM 5mm
It looks much like those smaller caps.
You mean coupling capacitors? Isn't this a stereo circuit?
Jan
Yea coupling, I mean those 2 big are each in parallel with one smaller near them![]()
Ahh! Yes you see that often in an attempt to impress.
BTW You do know that there is no such thing as an 'audio capacitor', except for marketing purposes ;-)
Jan
Looks like polycarbonate stacked film (low inductance), no longer obtainable I believe.Google says its Metallized PET Stacked. I dont see this kind of cap often, where is it used?
Oh, You can get them https://www.newark.com/epcos/b32561j1105k000/polyester-film-capacitor-1uf-100v/dp/25M8103
It turns out there are also polyester in this welded stacked package type, but when first introduced this was polycarbonate only. Polycarbonate dielectric film is no longer obtainable I believe. This package is a liability if you forget its got exposed metal and layout a pcb so that neighbouring components can short out. Much lower inductance than many film cap styles though.
- Design & Build
- Parts
- Where is this kind of cap used?
