Hi guys,
I'm building a 2.1 system. I'd like to have control over the power of the sub. Where do I put the pot? I have 2 boards that make up the sub portion. A preamp board and the actual power amp board. Do I put it even before the preamp board?
Thanks.
Thanks.
I would imagine that the pre-amp board provides the filtered signal for the sub, therefore if you want to adjust the sub level the pot must go after that.
Here's the board: Subwoofer (12HZ-48HZ)+(28HZ-112HZ) preamplifier board | eBay
It seems like it has adjustable filters. Like a mixer...
So in between the preamp and the power amp? How do I know what value to use? 10K?
Thanks a lot.
Thanks a lot.
I don't know how they do it... I couldn't even buy the parts for that price.
Yes 10k log should be ok, depends on the input impedance of your amp.
