Where did this amplifier board came from (VINTAGE!)
Here is the schematics of the Russian clone. It is pretty much the same as the original.
As that amp is running only on +/-24V, some resistor values were changed, the dropping resistors for the Zeners and resistors in the current limiter stages.
One interesting change is that the pole of the low-pass filter after the op-amp was moved up by a decade.
Peter
  • Russian Quad Clone.pdf
