Where can I source the Little Dot I+ enclosure?
I have a Little Dot I+ that has lost the bottom of the case! I have searched on eBay and some of the parts shops and only found cases that are not the same size. Is it possible to buy another case somewhere on the internet that is the same as this so I can replace the bottom?
This case is approximately 154mm x 92mm x 40mm
Your help is greatly appreciated.
