I need some big caps around 22000uf 63 or 125v they are to expensive in NZ so I want to get them off the net from the US maybe .They are around $80 here
US is not a problem how much do you want for them and what others do you have I have a freind that is looking for some caps as well around 100v 10000uf up .thanks for the email about the transistors I am looking into using them
Try recycling parts out of destroyed circuits that already exits. I have taken PWR transformers, rectifiers, caps, heat sinks from TV sets, amps, ECT. Much cheaper. One man's junk is another man's treasure...🙂
I also have several 68000uF in 50 v
15000uF (Adcom) in 100v
24000uF in 45v (Nelson's choice ... taken out of a Forte amp)
2X 56000uF in 63v
several 15000uF in 63v etc.
2X 56000uF in 63v
- where can I get big caps from
