DIY transformers...
Hello,
There's a lot of information in the Radiotron Designer's Handbook on the design of audio transformers of various types and constructions. Copies may be available on CD from AudioExpress (was Audio Amateur?).
However, the practical difficulties involved in making sure the windings are balanced and so on might make them difficult for the enthusiastic amateur. If you have access to professional winding equipment and the appropriate core material, you might be able to do it.
Good luck, Keith
Hello,
Good luck, Keith
Try:
<a href="http://www.geofex.com/Article_Folders/xformer_des/xformer.htm">Output Transformer Design and Winding</a>
<a href="http://homepages.enterprise.net/icedragon/new/distribu.htm">Types of Distributed Loading</a> see refs at end of page
<a href="http://home5.inet.tele.dk/mcs/Transformer.html">Push-Pull Transformers.</a> Originally by E.A.Schulze, Funkschau 1966, No.1, p.27f
<a href="http://www.autocostruire.it/">Air cored Output Transformers</a> Italien but has an English link
Hope these help
James
Hope these help
James
output transformers....
Hi dinamic1
The design of audio transformers as to the inductances and so on is relatively easy. The difficult bit is deciding which construction method (random, layered and sectional) to use and how to go about it.
If you want the relevant pages from the Radiotron, I could copy them and send to you.
My email address is in the information section here.
regards, Keith
Hi dinamic1
regards, Keith
Labour Intensive
For best performance you need sectioned windings, with primary sections wired in parallel, and secondary sections wired in parallel.
All paralleled sections need to have EXACTLY the same number of turns, or else you will have shorted turns. THIS WORKS !.
This technique averages induced flux density and gives reduced distortion.
Regards, Eric.
If you hunt, you may find a paper copy of The Radiotron Designers Handbook, but they are sought after and expensive.
There is a cd-rom reprint version too.
Regards, Eric.
- Tubes / Valves
- Where can i find information about diy output transformers?
