I'm trying to find a DC connector to supply a unit I'm going to make but I can't work out for sure which would match what, for instance would this socket fit with any of the connections on this plug? Any good guidelines to follow when selecting these separate parts?
Any help on this would be greatly appreciated cheers!
The short answer is they'll probably fit. The jack is 5.7mm outer diameter, 2mm pin diameter.
One of the plugs is 5mm outer, 2.1mm pin hole diameter.
According to the jack specs the plug should be 5.5 outer diameter but that is generally not a critical measurement as long as it isn't too large. It's generally the pin diameter that is critical.
Personally I'd avoid that type of plug for anything critical. There's too much risk for polarity screw-ups and the plug will pull loose very easily.
