The Pied Piper has no top..
The Auris is open round the back (see picture)
http://home.planet.nl/~jmhkort/afbeeldingen/aurisklein_gespiegeld.gif
Could they still be considered dipoles though?
I am planning to build dipole Straight 8's with a Focal tc120 tweeter ...But I was thinking that if I lengthen the "wings" that I would get more bass but retain some of the advantages of a dipole.
Bas
PS..right now my plan was to build it like this
|____|
The width would be the same as a straight 8 but the part part behind the baffle would only be 6cm long...
Bas
|____|
I recently tried a deepish cowl on the rear of my open-baffles and, as expected, it did improve the bass slightly. BUT it also took away some of the di-pole 'magic'!
You are right to ask this question but probably, only experimentation will provide you with the answer when the di-pole effect is diminished.
Konnichiwa,
Yes, modified.
If you put "wings" on a dipole you only extend the LF response a little but introduce a lot of added resonance from the cavities created. The Auris and it's original the Auditorium 23 Rondo use sweeping curves to minimise the resonances and thus can put substantial "wings" on that do give a substantial extension of the LF response....
Sayonara
Yes, modified.
Sayonara
Thanks Nuuk and Kuei Yang Wang..
Guess the experimentation is most important...I live 15minutes away from Jim de Kort (Auris builder) and have visited him a few times...but asking him to build my enclosures will be to xpensive..Maybe I can steal some of his ideas...build a plain one like I am planning..and later try my hand at an auris type of thing..
Maybe that won't even be necessary....since I read this bit on your site Nuuk
The big surprise is that I don't notice any reduction in the bass with the baffles compared to the ported cabinets!
Bas
Yes, but that was with the big cowl! With my larger open-baffles I am going to try some EQ first and maybe some additional woofers.
