I was wondering...
Does this chip have an serial i2s out? The datasheet are only the short version and it doesn't say clearly.
http://www.sonysemiconductor.co.uk/pdfs/cxnews/CX9 New Products CXP401.pdf
Any help are appreciated very much
Hi Thomas,
I didn't see any mention of I2C, but it is pretty easy to implement an I2C Master in software as long as you have two spare port pins.
An I2C Peripheral interface is a very different story. Then you need to use a maskable external interrupt pin to detect a start condition. Much more complicated and will consume a lot of the processors bandwidth (if there are other I2C peripherals on the bus).
What are you planning on doing that needs I2C? Are you going to control some I2C peripherals (easy to do) or do you want to become an I2C peripheral (more difficult without hardware support).
P.S. I implemented an I2C master in software on an 8052 running at 12 MHz and data transfers ran at about 40 KHz. If you need to run faster than that then either use a faster processor or a hardware implmentation of I2C.
Philips is the best source of I2C info (they have the patents on I2C). Checkout their website.
Phil
Phil
Thomas,
Hard to say, from figure 1 there isn't any. From figure 2 maybe the datao/xlto/clko. It is probably some dig audio out, but if it is i2s or some other protocol used is hard to tell.
It is probably configurable via the CPU interface. You have to try to get more info.
On the other hand, the chip is used to make a 'one chip' solution for CD players, so you don't need the i2s interface anymore internally between dig filter+dac. So maybe there's only SPDIF for the normal digital out.
For the other reaction i2s != i2c..
Greetings,
Guido
Greetings,
Guido
guido said:Thomas,
Greetings,
Guido
Sorry, I didn't read the inital post correctly, My BAD.
Phil
You have all been helpfull. I guess I have to get the full datasheet and or the service manual to be shure, but i dont' know where to find them.
I sort of didn't tell you first, but I wanted to know if I could connect a custom DAC not using the SPDIF.
Anyone know where I can get this:
CXP401 datasheet
Cambridge Audio D300SE service manual
Any service manual with a description of CXP401 could also be used.
Thomas
CXP401 datasheet
Thomas
