Whats the SPL at source (@0 m) when SPL is 90dB@1M?
In theory, SPL should be infinite, and you should have an infinitesimal source, that´s why it´s called a "point" source.
By definition, a point has size/dimension zero.
But of course there is not such a sound source in practice, so you won´t have infinite SPL either.
Personal opinion, others may differ, smallest sound source possible is the voice coil diameter, either moving a rigid dome (this is true in dome tweeters and in a few speakers, such as old JBL, some of which had a rigid aluminum dome glued straight to voice coil, not somewhere on the cone) or driving a small cone slice just around it.
Of course, although not very rigid, a cone behaves quite close to a perfect piston, so actual radiating surface (and diameter) is significantly higher than plain voice coil diameter.
"A point source is a small source which alternately injects fluid into a medium and withdraws it." ~ Harry F. Olson - "Acoustical Engineering"
In the example considered earlier the source was assumed to have a surface area of 5 cm2, equivalent to a spherical "point source" of radius 6.3mm (less than 0.37 wavelengths at 20000 hertz). The SPL of 134 dB was calculated at the surface of this source.
Sound Fields - acoustic glossary - article
"Near Sound Field, that part of a sound field, usually within about two wavelengths of a noise source, where there is no simple relationship between sound level and distance, where the sound pressure does not obey the inverse square law and the particle velocity is not in phase with the sound pressure.
Near Sound Field Definition IEC 801-23-29, sound field near a sound source where instantaneous sound pressure and particle velocity are substantially out of phase"
Web search for "near field effect" and you will find you tube videos and more.
