Hey guys,
I'll be getting a couple of Panasonic WM-61A from Digikey so that I can build a mic/preamp setup for frequency response testing. I've seen a preamp from Eric Wallin's site here , but it seems a little too intricate.
Is there any basic, crude preamp I can build that will do the trick? I will be using Speaker Workshop for the readings.
Thanks,
CFC
Thanks,
CFC
CFC said:Hey guys,
Thanks,
CFC
this is another relativly low-cost approach:
https://securewsch01.websitecomplete.com/sharrongrp/shop/showDept.asp?dept=629
See also Elliot Sound Products, (ESP) at http://sound.westhost.com for a simple 3 transistor mic amp- PCB available.
PCB based on Wallin v2 schematic is available.
Quick, easy and cheap. I've used it for a while and it does everything I need. One transistor circuit..........
http://www.tkk.fi/Misc/Electronics/circuits/micamp.html
Roger Hill
Roger Hill
Roger Hill said:Quick, easy and cheap. I've used it for a while and it does everything I need. One transistor circuit..........
Roger Hill
Roger,
You're a gentleman and a scholar 😀
This is exactly what I've been looking for.
Thanks a bunch,
I'll give an update on my setup.
CFC
Roger Hill
This is a bit worrisome: "Because of the simplicity of the design the distortion performance is not very good. At signal levels typically used by electret microphones the distortion is about 2-3%."
Here's an easy design with better performance:
http://www.linkwitzlab.com/sys_test.htm#Mic
- What's the simplest mic preamp I can build?
