what's the best way to convert SPDIF into CMOS level?
Hello all,
I'm working with DIR1701 as receiver. However, it's D_in only accept CMOS level, I need to convert SPIDF signal into CMOS level.
TI (on DEM-DIR1701 instruction manual) suggest using a two stage 74HCU04 buffer to do the level convert. Is there a better way to do it? Or are there any "low jitter" gates for building the buffer??
Thanks in advance.
banana said:
Guido,
About the Opamp approah. Do I need to add bias to the SPDIF signal before feeding it to the Opamp? I mean offsetting the "bipolar" +0.25/-0.25V input signal into "single-ended" +2.75/+2.25V, before amplification.
Or should I run the Opamp with +5V single supply and simply clip the output to +5/0V?
Hi
Yes, need bias at half of supply voltage
NEVER clip digital signal;s at such important places
regards
S/PDIF Input
You can't use most op-amps because the signal is in the 6 MHz range. If the lvel is too high coming from your source, you can attenuate it with a resistor. However, I use a 74AC04 operating on a 3.3V supply to buffer the input on my unit. You don't need anything fancier. On the electrical input, I couple the S/PDIF signal through a DC blocking capacitor to the input of the 74AC04 through a 220 ohm resistor. The input is biased with two resistors to 40% of the supply voltage.
On my opto input, the output of the TORX141 is buffered through another section of the 74AC04.
A little sharing, though most of you might already know. TTL gate does not work in the case of U3 on DEM-DIR1701 instruction manual. The first gate is actually a linear amplifier and only CMOS gates are suitable for doing this.
Before I learned this, I tried 74F04 and 74LS04. No matter how I bias the input DC, these TTL gates won't have symmetric output duty cycle. And they don't amplify, instead they simply switch on or off.
Finally, I settle on ADM1485. It's plug and play, trouble free. Thanks Andrei.
