many thanksI had the 165-2000 (mk1) for a good while, absolutley superb midrange and treble. Only sold as we were moving house/downsizing etc.
Most likely not talked about due to the price ~700Euro each, and Supravox themselves have had some supply issues over the past few years, moving manufacturing/owner etc. My first pair were quite far out of spec and had to be re-manufactured at Supravox (at their expense) and the second pair were well matched to the advertised spec.
Supravox 165-2000 by Robert Seymour, on Flickr
Supravox 165-2000 (R) Distortion by Robert Seymour, on Flickr
do you happen to have more measurements?
im very happy with how it measures and i might go with that driver as its much more efficient then what ive decided to go with!
I don't to hand. I believe the newer Mk2 version should be better, with a Qts of ~0.7 its easier to design cabinets for, along with a larger magnet/lower Qes can only be good!many thanks
Hi,"MAOP10" is the best choice for sound quality, and "TangBand W5-1880" is next best.
"CHP-90 mica" is the best choice for cost performance, and "Alpair10.3" is next best.
In terms of sound quality the Markaudio CHP-90 is it better than the new 8" fullrange from SB Acoustics SB20FRPC30-8?
FE108e∑ bought!
they are gorgeous drivers
will try with a couple of 15" and 12"
should i try 200 or 300hz with the small 108e∑?
I find the CHP-90 betters my prior favourite. It is a such an easy and satisfying listen with plenty of sparkle. Definitely the best mark audio driver I've heard so far.Hi,
hey daveFE108e∑ bought!
Ive finished the box for the 12" + 4". should i build a sealed sub-enclosure to isolate the wideband from the woofer?
if so, should i go sealed, or aperiodic?
ill go sealed sub enclosureYes, midTweeter needs to be isolated. Sealed, or aperiodic midTL (i like the latter).
dave
would 2L - 3L be enough?
You want it large enuff to have a Q=0.707 or less. Given teh FE108e∑ 2-3 litres is likely good. No power here, can’t look it up.
dave
dave
FE108ESigma? Assuming modest damping & a low leakage level, Butterworth is about 1.2 litres (effective).
- Full Range
- What's the best 4-8" wideband you heard reproducing the midrange/treble?
