Do you mean the VPR, Vertical Polar Response, at the FRD consortium?
http://www.pvconsultants.com/audio/frdgroup.htm
Why do you want to delete the thread when you find out?
Try using this program. It is for baffle simulation, but will model multiple drivers also.
http://www.tolvan.com/edge/
Andrew
Andrew
454Casull said:Well, I'd like to simulate the response for 2 identical drivers aligned vertically (i.e. the woofers in a MWW box).
Then I would imagine the VPR program is what you would use instead of the ARPE program.
By the way, I tried the VPR program and it looks good, but I don't know how to read waterfall plots. So it was of limited usefulness for me. But perhaps not for you.
I think there is a thread around here somewhere about reading waterfall plots. Hmmmm.
PS: That Edge program looks very useful,AndrewJ. Thanks.
The problem with the VPR spreadsheet is that the response changes radically as you increase the number of samples per octave - yet, intuitively, it seems that by increasing the number of samples, the response becomes more accurate.kelticwizard said:
- What's that program that simulates speaker lobing?
