What’s On the Bench Tonight (OBT)
I think the commercial version is the Aspen Titan? Hugh can confirm.
@AKSA certainly designed a sweet sounding amp in the Deltic.
Here is the Titan:
https://www.diyaudio.com/community/threads/new-aspen-125w-amplifier-the-titan.380033/
Reactions: maty tinman
I am pretty pleased with the Denafrips Ar-se (streaming module) outputting I2s into my Denafrips Pontus 12th in my Roon inviroment. My pi w/dac hats pale by comparison. The Allo bridge with a Denafrips Iris DDS,into the Schiit Bifrost 2/64 does come as a surprisingly strong second. I look forward to more audio specific streaming modules being offered.
Bill
Reactions: xrk971
We have a couple of new products under development. These are in the power conditioning arena.
Infinity Fuse is a solid state relay programmable fuse with solid state soft start relay for audio products. Think of it as a low impedance fuse and soft start solution in one.
Programmable (hardware - no software or micro controllers) for 1A to 15A and slow or fast blow.
We also have another product called Snub Station Zero that provides DC block for mains, and high performance EMI filtering (Schurter filters on 2 and custom one for soft start enabled one) for up to 3 outlets.
These circuits are all based on real engineering and sound electrical design. No HiFi Phoolery here. 🙂
Interesting - is the infinity fuse the successor to the Swiss Digital Fuse Box?
Nice work X,
Did you use solder paste and fry pan batch method for the bottom side or individual soldering of each piece?
MM
These were factory assembled for SMT. I only installed the TH parts (totally easy). I think I’ll offer these as fully SMT assembled boards in my shop.
This is what they look like from the factory.
There are 10 TH parts to install:
Volume pot
2x 3.5mm jacks
2x input capacitors (I used Silmic 10uF but 2.2uF Wima box cap works well.
1x 4 pin JST battery connector.
4x electrolytic rail caps (I used 100uF 35v) but 16v ones would be fine.
Factory installed 5532 opamps because OPA1642 was not in stock. Replacing that might improve sound quality a bit (but very subtle effect).
The two SMT LEDs serve to show amp channel is working, plus serves to set the voltage drop for the CCS reference.
